I have an attribute table that I would like to format. I need to display the numerical values in scientific notation (ie 2.367E-02 instead of 0.02367). How can I do this, especially for multiple fields at once, in ArcGIS Pro version 2.7?
Have you looked at https://pro.arcgis.com/en/pro-app/latest/help/data/tables/format-numeric-and-date-fields.htm ?
That shows how to format a field to scientific notation.
As for doing multiple fields at once, that is not currently possible. I'd recommend going to https://community.esri.com/t5/arcgis-pro-ideas/copy-number-formats-across-multiple-fields-in-fields-menu/idi-p/1023864 and adding your support by giving a kudo.
Hope this helps!
I've encountered an issue where the scientific notation formatting isn't carried over when I export the table. Should I create another post for this?
No worries. Glad I could help. Please mark the response as an accepted solution to help other community members.
Cheers
Thank you so much! I appreciate your help.
