For a form designed within Survey123 Connect, field users are not able to collect / map a polygon for a geoshape question. Survey works fine for field folks on iOS devices, but not on Android devices (Juniper Systems CT8 and Samsung Galaxy Active2). The initial polygon icon has a cross through it and does not open up on the Android devices.
I have also tested to see if defining capture methods to vertex or sketch. This did not fix the problem either. Any thoughts or known issues?
S123 Connect version 3.12.232
Attached is a simple test survey used to troubleshoot.
