I have a date field which I'd like it to be a date field with two values - from & to. I need it to be like a range. Have two values, a starting date and and end date.
Can this be done somehow?
yes, this is possible. you would want to stick to the way this is done in ISO 19115/19139 metadata for time period type extents though. See for example this snippet:
<gmd:temporalElement> <gmd:EX_TemporalExtent> <gmd:extent> <gml:TimePeriod gml:id="1624374152364r23014781936280926"> <gml:beginPosition>2021-06-01</gml:beginPosition> <gml:endPosition>2021-06-22</gml:endPosition> </gml:TimePeriod> </gmd:extent> </gmd:EX_TemporalExtent> </gmd:temporalElement>
you can find this in the INSPIRE dataset editor in Identification > Resource > Extent > Temporal Extent.
the code for this can be found in: inspire/gmd/extent/TemporalElement.js and the associated template.
Marten,
Any other changes I need to make in order to save the metadata, regarding the temporal element? Once I click save, I get error 500 in console.
I think I also had to make changes, in other words add the new temporal element field in the Evaluator classes?
without seeing the editor, the XML, and/or the error, that is hard to say. Can you share screenshots/files of these 3 things? Does the editor allow you to view the XML? if so, can you add an example here of that?
Here is a link for the geoportal and here is the error I get
as well as this
Marten, I figured it out. Thank you for your help!
