I have a custom symbology layer that I am using in a web map (successfully) but when I try to use that web map in a web application (using the web app builder) the symbology doesn't show up how it's supposed to (pictures attached). Is this a known issue? Is there something special I need to do to the custom symbology?
These are not supported in 3.x JSAPI apps like WAB. If you use this in a 4.x app like Experience Builder the symbols will show up as expected.
Are these symbols coming from a web style?
@RussRoberts Yes, I published it from Pro.
Okay, thank you!
HI Rus - I am trying to solve a similar problem. I am publishing from ArcPro with no errors or warnings, using what i consider pretty basic styles. Any suggestions?
I want this:
But get this:
@Psoralea thank you for posting this! We're in the process of migrating from web app builder to experience builder but I had to update an authoritative layer today and the symbology wouldn't show up even if I changed it after the fact in the map viewer. This little check box worked like a charm!
