I have used the journey template with the aim of achieving something along the lines of the following:
https://experience.arcgis.com/experience/df36d88209d9458bbd5ecf85515de827/?data_id=dataSource_1-Silverwood_NH_Tour_Points_9868%3A2
However, I have found a couple of limitations with this approach:
Can anyone suggest any solutions? I don't want to use the developer edition, but simple code changes are fine.
Hi @Sburnh, for your first point you could connect to data in the Text widget. This is assuming you have the hyperlink stored in an attribute for that point.
For your second point, could you clarify what you would like the app to do beyond what your linked example already does?
