we hare experiencing a problem when a member of a large household does not consent the survey is then blocked for the following members. See examples below:
Attached a video and the xls form.
Thank you,
Irene
The behavior you're seeing appears to be caused by a bug that causes a repeat set by a repeat count to not set question values when editing the form from drafts. I've added this case to our repo so it can be addressed.In the meantime, you should be able to edit the time field from the inbox or sent box.
Alternatively, you could remove the repeat count from the repeat and allow the user to manually add the repeat for each household member. This option isn't as ideal as your current configuration, but it's an option if you need to be able to edit repeats from the drafts folder.Thanks,-Barbara
