I have 20m contours for the entire country and would like to use it to generate a terrain dataset that will be used with Arc Hydro to calculate catchment characteristics i.e. area, longest water course, 10/85 slope etc. I'm considering generating a DEM for each contour sheet using a 10m cell size and then converting the DEM into a point shapefile. I'll then convert the point shapefile into a multi-part point shapefile, thereby reducing the records per point. Is my approach going to produce a better terrain than using the contour lines to generate the surface. Regards
The help has some good starter documentation on some terrain best practices.Overview of Terrain DesignBest Practices
