Hello, I've been having an issue while trying to execute webgisdr. I am not able to find the correct command to run it. I've been using this documentation: https://enterprise.arcgis.com/en/portal/latest/administer/linux/create-web-gis-backup.htm
arcgis@ip-172-31-30-16:/arcgis/portal/tools/webgisdr$ ./webgisdr --export --file /arcgis/portal/tools/webgisdr/exportgisdr.properties
bash: ./webgisdr: No such file or directory
arcgis@ip-172-31-30-16:/arcgis/portal/tools/webgisdr$ ./webgisdr.sh --export --file /arcgis/portal/tools/webgisdr/exportgisdr.properties
./webgisdr.sh: 5: [: x: unexpected operator
./webgisdr.sh: 29: ./webgisdr.sh: /bin/java: not found
arcgis@ip-172-31-30-16:/arcgis/portal/tools/webgisdr$ cd ..
arcgis@ip-172-31-30-16:/arcgis/portal/tools$ ./webgisdr --export --file /arcgis/portal/tools/webgisdr/exportgisdr.properties
bash: ./webgisdr: Is a directory
arcgis@ip-172-31-30-16:/arcgis/portal/tools$ webgisdr --export --file /arcgis/portal/tools/webgisdr/exportgisdr.properties
webgisdr: command not found
arcgis@ip-172-31-30-16:/arcgis/portal/tools$ cd webgisdr/
arcgis@ip-172-31-30-16:/arcgis/portal/tools/webgisdr$ webgisdr --export --file /arcgis/portal/tools/webgisdr/exportgisdr.properties
arcgis@ip-172-31-30-16:/arcgis/portal/tools/webgisdr$ webgisdr.sh --export --file /arcgis/portal/tools/webgisdr/exportgisdr.properties
webgisdr.sh: command not found
arcgis@ip-172-31-30-16:/arcgis/portal/tools/webgisdr$ nano webgisdr.sh
Thank you!
