I'm trying to figure out if it is possible to reference the value of a selector widget in ArcGIS Dashboards with an Arcade Expression for a List.
Here is a use case: Use the Selector Slider Widget to select a monetary value. The Arcade Expression within the List takes the feature's shape length and multiplies it by the user defined monetary value via the Slider Widget and displays that calculated value.
I've only found one example that has this type of user interaction but it uses a webscene: https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=scene-elevationinfo
