Hello All,
I guess the Subject question is not completely correct - in the way that I am thinking.
I am here to ask if I am understanding correctly - There is a way to "connect" GeoEvent Server to a table (or view) in a in a non-spatial or non-SDE database. Maybe the correct way of saying this is that we can register a database (in my case PostgreSQL) with ArcGIS Server and then, in GeoEvent, connect to the Feature/Web service that is now available in Server.
Am I getting this concept right? Here's my workflow:
- Create a Database Connection to generate an .sde file through ArcGIS Pro.
- Add a user maintained data store within Portal. (I believe that registering the db connection as a data store within the federated ArcGIS Server would be an alternate way to do this.)
- Publish layers in bulk from a user-managed data store
My db user has all of the correct privileges....
In this scenario, should I be able to utilize a "Poll an ArcGIS Server for Features" input to grab the most recent events from those published payers?
Thank you for your help,
--Adam
