Has anyone implemented the javascript FeatureTable digit such that selections between it and the underlying featurelayer are synchronized?
Not sure if you've had a chance to look at the Esri example - ArcGIS API for JavaScript Sandbox
There's an event "dgrid-select" to which you can attach, something like:
on(myTable, "dgrid-select", function(evt){
console.log("The dgrid-select event - ", evt);
In "evt", you can extract data from the selected row, e.g. evt[0].data.Cmn_Name, or maybe a unique identifier.
From here, I imagine you can apply a selection using that info, maybe something like:
Feature layer with selection | ArcGIS API for JavaScript
You could probably put your selection logic in the "dgrid-select" event - not sure if you need to do multiple selections, though. If so, you can probably work something out!
Thanks, that satisfies a portion of the need. Do you know how one would select a table row using the OBJECTID. Also, do you know how to refresh the featuretable after a new feature is added or an existing one is updated?
Love an answer to your 2nd question if someone knows the answer - how to refresh a featuretable.
For your 1st question this worked for me. (sorry couldn't get it formatted correctly)
"featureLayer" : AppLayer,
"map" : map
}, 'divApps');
appTable.startup();
on(appTable, "dgrid-select", function(evt){
// fires when a row in the grid is clicked
AppLayer.selectFeatures(EditQuery, esri.layers.FeatureLayer.SELECTION_NEW, function (features) {
Thanks much. Interesting. The form on(appTable, "dgrid-select", function(evt){ }); is in the example and works for you but does not work for me. I had to use the following: appTable.on("dgrid-select", function(evt){ });
