Hi, I have been trying to populate a span control with a field from the popup. This span control is located outside of the popup template and map view ... any pointers on how to do this? Best
i am trying to pass a field from popup to the span or asp control ... hopefully posted code will help? thanks
<%@ Page Language="C#" MasterPageFile="~/Main.master" AutoEventWireup="true" CodeFile="InstreamMap.aspx.cs" Inherits="ModelData_InstreamFlows_InstreamMap" %>
<asp:Content ID="Content" ContentPlaceHolderID="MainContent" runat="server">
<link rel="stylesheet" href="https://js.arcgis.com/4.18/esri/themes/light/main.css" /><link rel="stylesheet" type="text/css" href="../../Content/MapPages.css" /><script src="https://js.arcgis.com/4.18/"></script>
<script>require(["esri/config","esri/Map","esri/views/MapView","esri/layers/support/LabelClass","esri/layers/FeatureLayer","esri/widgets/BasemapToggle"], function (esriConfig, Map, MapView, infloLabel, FeatureLayer, BasemapToggle ) {
//Set api keyesriConfig.apiKey = "keyhere";
//Create mapconst map = new Map({basemap: "arcgis-topographic" // Basemap layer (eg. arcgis-topographic, hybrid)});
//Create viewconst view = new MapView({map: map,center: [-120.478851, 38.575764],zoom: 7,container: "mapDiv",constraints: {snapToZoom: false}});
//Create labelconst inflowLabel = { // autocasts as new LabelClass()symbol: {type: "text", // autocasts as new TextSymbol()color: "#00008B",font: { // autocast as new Font()family: "Segoe UI",size: 10,}},
labelPlacement: "above-right",labelExpressionInfo: {expression: "$feature.PointName"},
maxScale: 0,minScale: 25000000};
//Create popup templateconst inflowPopup = {// autocasts as new PopupTemplate()title: "{PointName}",content: [{// It is also possible to set the fieldInfos outside of the content// directly in the popupTemplate. If no fieldInfos is specifically set// in the content, it defaults to whatever may be set within the popupTemplate.type: "fields",fieldInfos: [{fieldName: "PointID",label: "ID:"},
{fieldName: "DataSource",label: "Data Source:",format: {digitSeparator: true,places: 0}},
{fieldName: "DataType",label: "Data Type:",format: {digitSeparator: true,places: 0}},
{fieldName: "RefDate",label: "Reference Date:",format: {digitSeparator: true,places: 0}},
{fieldName: "EditedDate",label: "Edited Date:",format: {digitSeparator: true,places: 0}}]}]};
//Create/add basemap toggle//const toggle = new BasemapToggle({// view: view, // view that provides access to the map's 'arcgis-topographic' basemap// nextBasemap: "hybrid" // allows for toggling to the 'hybrid' basemap//});//view.ui.add(toggle, "top-right");
const inflowRenderer = {type: "simple", // autocasts as new SimpleRenderer()symbol: {type: "simple-marker", // autocasts as new SimpleMarkerSymbol()size: 6,color: [230, 149, 0],outline: null}};
//Create feature layervar featureLayer = new FeatureLayer({url:"https://gis.water.ca.gov/arcgis/rest/services/InlandWaters/i12_CalSimII_InflowData/FeatureServer?f=pjson",renderer: inflowRenderer,popupTemplate: inflowPopup,labelingInfo: [inflowLabel]})map.add(featureLayer);});</script><dx:ASPxCallbackPanel ID="ChartCallbackPanel" ClientInstanceName="CallbackPanel"OnInit="CallbackPanel_Init"runat="server"><SettingsLoadingPanel Enabled="true" /><PanelCollection><dx:PanelContent><dx:ASPxPanel id="panel1" runat="server" ><PanelCollection><dx:PanelContent runat="server">
<div><div class="left-map-div"><div id="mapDiv" class="map-view"></div></div>
<div class="right-charts-div">
/////////// Pass field Point ID from popup to span or asp server control ///////////////<span id="pointID"></span><asp:Label ID="pointID" runat="server"></asp:Label>////////////////////////////////////////////////////////////////////////////////////////
</div>
<div style="clear:both"></div></div></dx:PanelContent></PanelCollection></dx:ASPxPanel></dx:PanelContent></PanelCollection></dx:ASPxCallbackPanel></asp:Content>
