I've a problem that ArcGIS Pro freezes when I try to open the analysis pane.
It used to work fine with no issues, until I wanted to install some Deep Learning libraries, I cloned the existing python environment to a new one and installed the require extensions, finished work with it and returned back using the original environment.
While afterwards I noticed that ArcGIS Pro freezes whenever I try to open the analysis tab, but all geoprocessing tools run fine with no problem. This only happen if I try to open the analysis tab.
I tried to open ArcGIS diagnostic monitor and found the following process to be causing the issue:
"ArcGIS.Desktop.Mapping.InteractiveAnalysisDockPaneViewModel.LoadDeepLearningLayers+"
I uninstalled and reinstalled ArcGIS Pro and the problem still exists.
Can somebody help with the cause and remedy of this problem?
