Hello All,I am facing issue while using Arcgis/core 4.18. My map canvas height keep increasing. I am using Arcgis/Core with Angular 11.
Here is my code
app.component.html
I've seen this happen if you don't have the CSS for the ArcGIS JSAPI included in your application.
Yes finally its resolved by Js-api and its working fine Thanks a lot guys.
I took a quick look at your code. There are several issues.
The main one (causing the endless div resize) is this:
@import "@arcgis/core/assets/esri/themes/light/main.css";
Should be in your main styles.scss. Not in the scope of your app.component scss.
Secondly, your app layout is not good if you wish a fullscreen map application.Your styles.scss file should contain something like:
html, body { height: 100%; }
Then your app.component.html file mention a html-head-body hierarchy that is already in index.html.This is screwing your vertical positioning.Keep it simple like this:
{{title}}<div id="viewDiv"></div><router-outlet></router-outlet>
@GiovanniVanore1 I'm not sure what's going on, I tried just about everything to get the app running right. My recommendation is to start fresh using our Angular sample app: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-angular-cli.
@ReneRubalcava Yes, I have added ArcGIS JSAPI . Still getting same issue
Thank you
@AndyGup this is the github link.
https://github.com/guptarahul14/sampleApplication/tree/master/sampleProgram
Hi @GiovanniVanore1 this doesn't sounds like it's related to the ArcGIS API for JavaScript. Can you provide a simple github repo that reproduces the issue?
