define( [ "dojo/_base/declare", "esri/layers/ArcGISImageServiceLayer" ], function( declare, ArcGISImageServiceLayer ) { var MyImageServiceLayer = declare([ArcGISImageServiceLayer], { declaredClass: "esri.layers.ArcGISImageServiceLayer" }); return MyImageServiceLayer; });
var map, layer; require(["esri/map", "esri/layers/MyImageServiceLayer", "esri/dijit/Print", "dojo/domReady!"], function (Map, MyImageServiceLayer, Print) { esri.config.defaults.io.proxyUrl = "/proxy.ashx";//use your own proxy instead of this. map = new Map("map", { basemap: "gray", center: [-80.85, 35.22], zoom: 14 }); var print = new Print({ map: map, url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task" }, "print"); print.startup(); layer = new MyImageServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/CharlotteLAS/ImageServer"); map.addLayer(layer); layer.on("load", function () { layer.renderingRule = { "rasterFunction": "RFTShadedReliefElevationColorRamp" }; layer.renderingRule.toJson = function () { return { "rasterFunction": "RFTShadedReliefElevationColorRamp" }; }; layer.setRenderingRule(layer.renderingRule); }); });
require(["esri/tasks/PrintTask","esri/tasks/PrintParameters","esri/tasks/PrintTemplate","mapui","mainmodel"], function(PrintTask,PrintParameters,PrintTemplate,MapUI,MainModel){ var printConfig = Config.getConfig().print, printTask = new PrintTask(printConfig.url), params = new PrintParameters(), viewModel = MainModel.getVM(); params.map = MapUI.getMap(); params.template = new PrintTemplate(); params.template.label = printConfig.template.label; params.template.format = printConfig.template.format; params.template.layout = printConfig.template.layout; params.template.layoutOptions = printConfig.template.layoutOptions; var languageIsEnglish = (query(".selectedLanguage")[0].id === "languageEnglish"); if(languageIsEnglish) viewModel.printMap("Printing"); else viewModel.printMap("Printing"); printTask.execute(params,function(response){ window.open(response.url); if(languageIsEnglish) viewModel.printMap("Print"); else viewModel.printMap("Cetak"); },function(error){ if(languageIsEnglish) viewModel.printMap("Print"); else viewModel.printMap("Cetak"); }); });
print: { url:"http://gis-stage.wri.org/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task", template: { label:"Map", format:"PNG32", layout:"A4 Landscape", layoutOptions: { titleText: "Suitability Map", authorText: "WRI & esri", copyrightText: "WRI", scalebarUnit: "Miles" } } }
getImageUrl: function (extent, width, height, callback,options) { var _self = this; var bbox = [extent.xmin, extent.ymin, extent.xmax, extent.ymax], params, min, max, tempArray, membership_arguments; var rasterFunction = _self.getRenderingRule(); if (options) { params = options; params['renderingRule'] = JSON.stringify(rasterFunction); params['bbox'] = bbox.join(","); callback(_self.url + "/exportImage?",params); } else { params = { noData: 0, noDataInterpretation: "esriNoDataMatchAny", interpolation: "RSP_BilinearInterpolation", renderingRule: JSON.stringify(rasterFunction), format: "png8", size: width + "," + height, imageSR: 3857, bboxSR: 3857, f: "image", pixelType: 'U8', bbox: bbox.join(",") }; callback(_self.url + "/exportImage?" + dojo.objectToQuery(params)); } },
PrintTask includes renderingRule if that property exists in your layer. Please check yourCustomImageServiceLayer.renderingRule is there, and yourCustomImageServiceLayer.renderingRule.toJson() is a valid function.
"{"rasterFunction":"PalmOilSuitabilityNew","rasterFunctionArguments":{"ElevRaster":"$1","SlopeRaster":"$2","WaterRaster":"$3","ConsRaster":"$4","STypeRaster":"$5","SDepthRaster":"$6","PeatRaster":"$7","SAcidRaster":"$8","SDrainRaster":"$9","RainfallRaster":"$10","LCRaster":"$11","ElevInpR":[0,100,100,1000000],"ElevOutV":[1,0],"SlopeInpR":[0,30,30,1000000],"SlopeOutV":[1,0],"WaterInpR":[0,10,10,1000000],"WaterOutV":[0,1],"ConsInpR":[0,10,10,1000000],"ConsOutV":[0,1],"RainfallInpR":[0,150,150,700,700,1000000],"RainfallOutV":[1,1,0],"SDepthInpR":[0,0,1,1,2,2,3,3,4,4,5,5,6,6,7,7],"SDepthOutV":[1,0,0,0,1,1,1,1],"PeatInpR":[0,0,1,1,2,2,3,3,4,4,5,5,6,6],"PeatOutV":[1,0,0,0,0,0,0],"SAcidInpR":[0,0,1,1,2,2,3,3,4,4,5,5,6,6,7,7],"SAcidOutV":[1,1,1,1,1,1,1,1],"SDrainInpR":[0,0,1,1,2,2,3,3,4,4],"SDrainOutV":[1,0,1,1,1],"LCInpR":[0,0,1,1,2,2,3,3,4,4,5,5,6,6,7,7,8,8],"LCOutV":[1,1,1,1,0,0,0,0,0],"STypeInpR":[1,1,2,2,3,3,4,4,5,5,6,6,7,7,8,8,9,9,10,10],"STypeOutV":[1,1,1,0,1,1,1,1,1,0]}}"
{ "mapOptions": { "showAttribution": true, "extent": { "xmin": -9002667.410873475, "ymin": 4193183.580948897, "xmax": -8996552.448610498, "ymax": 4195815.881110537, "spatialReference": { "wkid": 102100 } }, "spatialReference": { "wkid": 102100 }, "scale": 18055.954822005082 }, "operationalLayers": [ { "id": "layer0", "title": "layer0", "opacity": 1, "minScale": 591657527.591555, "maxScale": 9027.977411, "url": "http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer" }, { "id": "layer2", "title": "layer2", "opacity": 1, "minScale": 0, "maxScale": 0, "url": "http://sampleserver6.arcgisonline.com/arcgis/rest/services/CharlotteLAS/ImageServer", "bandIds": null, "compressionQuality": null, "interpolation": null, "renderingRule": { "rasterFunction": "RFTShadedReliefElevationColorRamp" } }, { "id": "layer1", "title": "layer1", "opacity": 1, "minScale": 591657527.591555, "maxScale": 9027.977411, "url": "http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Reference/MapServer" }, { "id": "map_graphics", "minScale": 0, "maxScale": 0, "featureCollection": { "layers": [] } } ], "exportOptions": { "outputSize": [ 800, 1100 ], "dpi": 96 } }
Can you post the web map json sent to print service?
require(["esri/request"], function(request) { request.setRequestPreCallback(function(ioArgs) { // if request is to the PrintingTools url // Get my Image Service Layer from ioArgs.content.Web_Map_as_JSON // Add in my rendering rule and rasterFunctionArguments // replace webmap JSON with updated JSON and request now uses POST instead of GET return ioArgs; }); });
I looked at the source code. PrintTask doesn't work with any custom layer. Because it checks the property layer.declaredClass to decide what to serialize into the json output.In your case, only when layer.declaredClass === "esri.layers.ArcGISImagerServiceLayer", it will serialize renderingRule.Is your custom layer written in AMD style or legacy style? You can try to override .declaredClass property as "esri.layers.ArcGISImagerServiceLayer". It shouldn't cause any conflicts.
define(["declare", "esri/layers/RasterFunction", "esri/layers/ImageServiceParameters", "toolsmodel", "dojo/_base/array", "dojo/_base/lang"], function (declare, RasterFunction, ImageServiceParameters, Model, arrayUtils, lang) { return declare("SuitabilityImageServiceLayer", esri.layers.ArcGISImageServiceLayer, { constructor: function () { // raster function arguments must be in same order as in image service moasic dataset this.rasterFunctionArguments = {}; this.rasterFunctionArguments.ElevRaster = "$1"; this.rasterFunctionArguments.SlopeRaster = "$2"; this.rasterFunctionArguments.WaterRaster = "$3"; this.rasterFunctionArguments.ConsRaster = "$4"; this.rasterFunctionArguments.STypeRaster = "$5"; this.rasterFunctionArguments.SDepthRaster = "$6"; this.rasterFunctionArguments.PeatRaster = "$7"; this.rasterFunctionArguments.SAcidRaster = "$8"; this.rasterFunctionArguments.SDrainRaster = "$9"; this.rasterFunctionArguments.RainfallRaster = "$10"; this.rasterFunctionArguments.LCRaster = "$11"; // scalars are harded-coded based on raster pre-processing scripts this.rasterFunctionScalars = {}; this.rasterFunctionScalars.Elev = 10; this.rasterFunctionScalars.Slope = 1; this.rasterFunctionScalars.Water = 10; this.rasterFunctionScalars.Cons = 100; this.rasterFunctionScalars.SType = 1; this.rasterFunctionScalars.SDepth = 1; this.rasterFunctionScalars.Peat = 1; this.rasterFunctionScalars.SAcid = 1; this.rasterFunctionScalars.SDrain = 1; this.rasterFunctionScalars.Rainfall = 10; this.rasterFunctionScalars.LC = 1; this.renderingRule = {}; this.declaredClass = "esri.layers.ArcGISImageServiceLayer"; var rasterFunction = new RasterFunction(); rasterFunction.functionName = "RemapColormap2Prashant"; rasterFunction.arguments = this.rasterFunctionArguments; var params = new ImageServiceParameters(); params.noData = 0; params.renderingRule = rasterFunction; this.imageServiceParameters = params; }, getExportUrl: function(extent,width,height,callback,options){ function callback(url){ return; } }, getRenderingRule: function () { //console.log("GET RENDER RULE"); var _self = this; var suitabilitySettings = _self.returnRasterSettingsAsObject(); var render_rule = {}; lang.mixin(render_rule, this.rasterFunctionArguments); _self.addThresholdArgument(suitabilitySettings, render_rule, 'Elev', _self.rasterFunctionScalars, 'MAX'); _self.addThresholdArgument(suitabilitySettings, render_rule, 'Slope', _self.rasterFunctionScalars, 'MAX'); _self.addThresholdArgument(suitabilitySettings, render_rule, 'Water', _self.rasterFunctionScalars, 'MIN'); _self.addThresholdArgument(suitabilitySettings, render_rule, 'Cons', _self.rasterFunctionScalars, 'MIN'); _self.addThresholdArgument(suitabilitySettings, render_rule, 'Rainfall', _self.rasterFunctionScalars, 'BETWEEN'); _self.addMembershipArgument(suitabilitySettings, render_rule, 'SDepth', [0, 1, 2, 3, 4, 5, 6, 7]); _self.addMembershipArgument(suitabilitySettings, render_rule, 'Peat', [0, 1, 2, 3, 4, 5, 6]); _self.addMembershipArgument(suitabilitySettings, render_rule, 'SAcid', [0, 1, 2, 3, 4, 5, 6, 7]); _self.addMembershipArgument(suitabilitySettings, render_rule, 'SDrain', [0, 1, 2, 3, 4]); _self.addMembershipArgument(suitabilitySettings, render_rule, 'LC', [0, 1, 2, 3, 4, 5, 6, 7, 8]); _self.addMembershipArgument(suitabilitySettings, render_rule, 'SType', [1, 2, 3, 4, 5, 6, 7, 8, 9, 10]); var rasterFunction = new RasterFunction(); rasterFunction.rasterFunction = "PalmOilSuitabilityNew"; rasterFunction.rasterFunctionArguments = render_rule; return rasterFunction; }, getImageUrl: function (extent, width, height, callback, options) { var _self = this; var bbox = [extent.xmin, extent.ymin, extent.xmax, extent.ymax], params, min, max, tempArray, membership_arguments; var rasterFunction = _self.getRenderingRule(); if (options) { params = options; params['renderingRule'] = JSON.stringify(rasterFunction); params['bbox'] = bbox.join(","); _self.renderingRule = rasterFunction; callback(_self.url + "/exportImage?",params); } else { params = { noData: 0, noDataInterpretation: "esriNoDataMatchAny", interpolation: "RSP_BilinearInterpolation", renderingRule: JSON.stringify(rasterFunction), format: "png8", size: width + "," + height, imageSR: 3857, bboxSR: 3857, f: "image", pixelType: 'U8', bbox: bbox.join(",") }; _self.renderingRule = rasterFunction; callback(_self.url + "/exportImage?" + dojo.objectToQuery(params)); } }, returnRasterSettingsAsObject: function () { var result = {}; var settingsArray = Model.getVM().suitabilityCustomSettings().computeBinaryRaster; arrayUtils.forEach(settingsArray, function (setting) { result[setting.name] = setting.values; }); return result; }, returnNumericArray : function (stringArray) { var temp = stringArray.split(","); var result = []; arrayUtils.forEach(temp, function (value) { result.push(parseInt(value, 10)); }); return result; }, addThresholdArgument: function (suitabilitySettings, renderRule, variableName, scalars, breakType) { var _self = this; scalar = scalars[variableName]; if (breakType === 'BETWEEN') { var tempArray = _self.returnNumericArray(suitabilitySettings[variableName + 'InpR']); var min = tempArray[0]; var max = tempArray[tempArray.length - 1]; renderRule[variableName + 'InpR'] = [0, min / scalar, min / scalar, max / scalar, max / scalar, 1000000]; renderRule[variableName + 'OutV'] = [1, 1, 0]; } else { var breakpoint = parseInt(suitabilitySettings[variableName + 'InpR'], 10); renderRule[variableName + 'InpR'] = [0, breakpoint / scalar, breakpoint / scalar, 1000000]; renderRule[variableName + 'OutV'] = breakType === 'MIN' ? [0, 1] : [1, 0]; } }, addMembershipArgument: function (suitabilitySettings, renderRule, variableName, allValues) { var _self = this; var validValues = _self.returnNumericArray(suitabilitySettings[variableName + 'InpR']); var input_values = []; var output_values = []; var includeNulls = ["SDepth","SAcid","SDrain","LC"]; var val; var i; if (includeNulls.indexOf(variableName) > -1 && validValues[0] !== 0) validValues.unshift(0); for (i = 0; i < allValues.length; i++) { val = allValues; input_values.push(val, val); if (validValues.indexOf(val) === -1) { output_values.push(0); } else { output_values.push(1); } } renderRule[variableName + 'InpR'] = input_values; renderRule[variableName + 'OutV'] = output_values; } }); });
