I think it is a good idea that survey123 will allow you to leave a survey as pending to carry out a second activity. as an example to close and open an aqueduct valve, I want in a single record to see when it was closed and then when the same valve was opened and to have a single geographical point for those two activities, I would like to see on the map the valves that are closed and pending to open, then complete the survey by opening the valve but only have a record of that
Es muy normal en cerrar y abrir válvulas que la primera actividad la realiza una persona y la segunda la siguiente que entra a trabajar
