A field worker using an iphone 8 is getting an 'Invalid Text' error when trying to identify a location via a Button user input. No issues for others using android devices. Is there a solution for this for those using ios?
Hi DEI,
Does the button user input has an input mask applied? It'd be helpful if you can share the user input configurations so we can try to replicate the problem. For now, you can try: (1) Update the QuickCapture app to the latest 1.9.127 version and see if the issue still exists. (2) Double-check the input mask (if it has) and add Hint text to demonstrate what is the expected input format. (3) Set the button user input as non-required, so user can Skip the dialog.
Mandy
