Hi folks,
I have a new installation of Workflow Manager for ArcGIS Enterprise 10.8.1. Workflow Manager is installed on its own ArcGIS Server machine which is federated with a Portal from a base deployment with a hosting server. Everything seemed fine - the WFM server federated, I designated the server as Portal's WFM server and I can get to the web app, but when I try and create a new Workflow item I get an error "Unable to create new Workflow item". When I look in the Portal content, I can see a Workflow and a hosted feature layer (workflow_<id>) have been created. When I refresh the web app, the Workflow appears but when I click it, it never loads.
In the Workflow Manager logs and dev tools, I get the following error when creating the workflow:
WorkflowDataStoreException: Unable to connect to Workflow Datastore
Would this be the ArcGIS Data Store on the hosting server? The Data Store seems to be functioning ok in that it validates and I can upload a zipped shapefile and publish as a hosted layer. The hosted feature layer that is created for the Workflow I can add to a map. Any idea what could be causing this error or more things I can check? Thanks in advance!
Alistair
