Hi Guys,
I am using API 4.18, I need to change Font in Popup, I need to use my local font. I could do it for API 4.13 using CSS, but now it stops working. How can I do this now?
Kind regards,
Vakhtang
Hi @Vakhtang_Zubiashvili, it's tough to say without seeing how you did it at 4.13, but my hunch is that the HTML sanitizer (which we introduced at 4.14) is the issue here:
https://developers.arcgis.com/javascript/latest/4.14/#breaking-changes
If this is the case, the alternative solution would be to use custom functions. Here is a blog post that details the issue and the workaround:https://www.esri.com/arcgis-blog/products/js-api-arcgis/mapping/using-html-with-popups-in-the-arcgis-api-for-javascript/
If this doesn't work for you, can you share some more details? I'd like to see how you are trying to do it at 4.18 (which worked at 4.13). A sample app on someplace like Codepen would be great.
Dear Noah,
Thank you for response, for 4.12 (or 4.14 I do not remember exactly) I used CSS code like this to change font style in Popup:
and it worked.
Now as you told me I tried something like this:
but no success.
What to do I do not know 😞
You
Hi there,
You should set the style on html elements like div, p, span etc.
The following will work for example:
var template = { // autocasts as new PopupTemplate() title: "{NAME} in {COUNTY}", content: '<div style="font-family:Garamond;font-size:26px"><i>content</i></div>' };
Dear @UndralBatsukh
Thank you for replay.
It works, but only for Font Size, Font Color etc. But not for Font Style. Font Style remains default Sans-Serif...
Code Template:
welltemplate = { title: "Well", content: "<div style='font-family:HKolkhetyMtav;font-size:26px;color:red'><li> Hello Guys</li></div>" };
I use local font for my native language ( It is Georgian), here is CSS for it:
If i change font style in browser for <li> it works fine ( I have changed default FONT into Georgian FONT ("Hello Guys" is translated as "ცელოო ჩუყს"), see pics please:
No one can help me 😞
