How to move and upgrade a wmx repo eGDB?
1. use a database backup
recommended, it is the easy way to move the geodatabase, especially if the geodatabase is quite large!
or
2. copy / paste wmx schema
create a new eGDB then use ArcCatalog or Pro to copy/paste the wmx schema
or
3. WMX Administrator export/import the wmx configuration
create a new eGDB then use the WMX Administrator to export / import the wmx configuration
if you want to keep the jobs data then instead use the "Export Job Data" GP Tool.
ArcMap WMX Classic:
https://desktop.arcgis.com/en/arcmap/latest/tools/workflow-manager-toolbox/export-job-data.htm
