Want to check if anyone has had success with the ArcGIS Runtime using Visual Studio Xamarin Forms on iOS using hot restart?
I created a new Xamarin Forms app for iOS in Visual Studio and added the following code in AppDelegate.cs
public override bool FinishedLaunching(UIApplication app, NSDictionary options)
global::Xamarin.Forms.Forms.Init();
LoadApplication(new App());
Esri.ArcGISRuntime.ArcGISRuntimeEnvironment.Initialize();
return base.FinishedLaunching(app, options);
The app launches and runs fine without the Initialize method on my iPhone. It feels like I'm missing a dependency.
This is the error I get:
[0:] An error occurred: 'CoreRT_ArcGISRuntimeEnvironment_setInstallDirectory assembly:<unknown assembly> type:<unknown type> member:(null)'. Callstack: ' at (wrapper managed-to-native) RuntimeCoreNet.GeneratedWrappers.CoreArcGISRuntimeEnvironment.CoreRT_ArcGISRuntimeEnvironment_setInstallDirectory(byte[],intptr&)
at RuntimeCoreNet.GeneratedWrappers.CoreArcGISRuntimeEnvironment.SetInstallDirectory (System.String installPath) <0x138775060 + 0x00010> in <2a33546a5b934b588629d4e33895c554>:0
at Esri.ArcGISRuntime.ArcGISRuntimeEnvironment.InitNative () <0x1387748c8 + 0x00004> in <2a33546a5b934b588629d4e33895c554>:0
at Esri.ArcGISRuntime.ArcGISRuntimeEnvironment.Initialize () <0x138774538 + 0x00042> in <2a33546a5b934b588629d4e33895c554>:0
at App1.iOS.AppDelegate.FinishedLaunching (UIKit.UIApplication app, Foundation.NSDictionary options) [0x00013] in C:\Users\Chris\Documents\OnScene Xplorer\App1\App1.iOS\AppDelegate.cs:33
at (wrapper managed-to-native) UIKit.UIApplication.UIApplicationMain(int,string[],intptr,intptr)
at UIKit.UIApplication.Main (System.String[] args, System.IntPtr principal, System.IntPtr delegate) [0x00005] in /Users/builder/azdo/_work/1/s/xamarin-macios/src/UIKit/UIApplication.cs:86
at UIKit.UIApplication.Main (System.String[] args, System.String principalClassName, System.String delegateClassName) [0x0000e] in /Users/builder/azdo/_work/1/s/xamarin-macios/src/UIKit/UIApplication.cs:65
at App1.iOS.Application.Main (System.String[] args) [0x00001] in C:\Users\Chris\Documents\OnScene Xplorer\App1\App1.iOS\Main.cs:17
at (wrapper managed-to-native) System.Reflection.RuntimeMethodInfo.InternalInvoke(System.Reflection.RuntimeMethodInfo,object,object[],System.Exception&)
at System.Reflection.RuntimeMethodInfo.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x0006a] in /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/src/Xamarin.iOS/mcs/class/corlib/System.Reflection/RuntimeMethodInfo.cs:395 '
Looks like its attempting to make a call into a native method using DllImport.
I also tried the sample app from ArcGIS and it also fails the same way once I enable hot restart on it.
Any ideas for how to fix this?
