There is a need to be able to access and edit the Popup Object in ArcPy to:1. Toggle the Popup on and off
2. Set expressions for the text
Some of this can be achieved via ApplySymbobologyFromLayer but the "showPopups" : false, setting does not seem to be honoured at the moment.See also: https://community.esri.com/t5/python-questions/arcypy-custom-pop-ups/m-p/538954
Leandra,
This can be done using Python CIM Access. Here is the help topic that describes what that means:
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/python-cim-access.htm
This sample below assumes popups are already configured and it only toggles the visibility. If they are not already configured and customized they can be with Python CIM Access as well but it takes more CIM work. See Creating CIM objects in the document above.
If you can give me an example of "Set expressions for the text" I can try to provide a sample snippet.
p = arcpy.mp.ArcGISProject('current') m = p.listMaps('Map')[0] l = m.listLayers('GreatLakes')[0] l_cim = l.getDefinition('V2') l_cim.showPopups = True l.setDefinition(l_cim)
Jeff - Layout and arcpy.mp teams
Works a Treat Jeff!!! Thankyou!!! 😀
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
