Moet ik VMap kunnen laden in ArcMap Desktop 10.2? De catalogus herkent het, maar wanneer ik probeer het naar mijn hoofdvenster te slepen, crasht ArcMap, geen foutmelding, het sluit gewoon.<\/P>
Doe ik iets verkeerd? <\/P>
When you mention VMap are you talking about VPF Data? And is it that you want to visualize the vpf data in ArcMap? You should be able to use the add data button and navigate to the VPF feature class and add it as a layer.
OK, thanks, seems to work if I use the Add data button. I usually just drag stuff in from the catalogue or Windows explorer.👍
Can you provide more information about the VMap item?
Is it related to this: VPF To Geodatabase—Help | Documentation (arcgis.com)Also, 10.2.x is retired and support for it may be very light.
