using Javascript API, how can comvine the CSV drag and drop example so that when I dropt the points in, it comes back with map of the points that lie withing extent of a multipoygon Gejson layer
Here is the point in extent example
https://developers.arcgis.com/javascript/3/jssamples/graphics_extent_query.html
Here is the drag drop example
https://developers.arcgis.com/javascript/3/jssamples/exp_dragdrop.html
In the drag drop example can I also use a webmap
you need to compare geometries of input points with the source polygon features/graphics using GemetryEngine (Contains function)
https://developers.arcgis.com/javascript/3/jsapi/esri.geometry.geometryengine-amd.html#contains
Hope this helps!,
Adam
