HI,
I had created a base map in ArcGIS Pro and published as Vector Tile layer and using the vector tile layer I can edit the published base map symbols to create an alternative visualization for the same base map in easy and fast way.
My Question: Is there anyway to import the edited VTL style to ArcGIS pro and apply it to the same base map which was originally used for publishing the VTL so it can look the same in ArcGIS Pro, So I can use it later for publishing either as VTL or Tiles map service.
