in ArcMap you used to be able to copy a feature from one version and paste it into another, can that be done in Pro?
Cheers
Yes! I've had to do it a few times myself, for various reasons. Simply select the features in one version, Ctrl + C, then in the main ribbon, click the arrow to choose Paste Special, then select the layer.
It's easiest if you have two copies of your layer in a single map and set them to the different versions you want to copy and paste between, but you can also do it between maps as well.
Thank you!
