I have a script that runs SummarizeWithin() as a step in the analysis process. If I pass it paths to feature classes within an on-disk gdb for the input and output data it runs fine, but if I try to use "memory" datasets ("memory/in_points" and "memory/out_hexes"), it fails with "ERROR 000187: Only supports Geodatabase tables and feature classes".
Does SummarizeWithin() not work with "memory" datasets?
