Is there a way to create a link of the current extent to open another web application?
I have to Web Applications both built in WebApp Builder (one in ArcGIS Online and one in Portal). I would like a link on the one Application (Online) that a user can click that opens the second application at the same extent.
I see in the Share Tool that I'm using it provides a URL to give to someone that has the current extent with the current map (see below). I pretty much want a similar link that pretty much does the same thing except where I can put the second application id in, instead of giving the current map.
https://xyz.org/parcgis/apps/webappviewer/index.html?id=xyz&extent=-10954836.1057%2C4952499.025%2C-10954582.1052%2C4952628.2742%2C102100
