In ArcGIS Pro, I know that the annotation is now updated automatically. Because of this how do you update the feature class in the geodatabase that the annotation is assigned to?
Hi Dan. So if I use the GP tool it updates the feature class right?? Just making sure I read correctly.
I would recommend upgrading to Pro 2.3.2 (it has a lot of updates for annotation) and running the GP tool. It does NOT upgrade the geodatabase but the feature class that holds the annotation.
All my work is in Pro already. I don’t need to upgrade the geodatabase. It’s already updated to the 2.1 ArcGIS Pro version. I need to update the feature class inside the geodatabase that the annotation is attached to.
The annotation is NOT upgraded automatically when you access it via Pro. You must run the Upgrade Dataset GP tool to do this: https://pro.arcgis.com/en/pro-app/tool-reference/data-management/upgrade-dataset.htm
