Hello
My apologies for the late reply.
Indeed, you can't append network features to the open diagrams in the following situations:
You must make sure that you are out of all these situations
Hello @AYBlin ,
I am also facing the same issue. I have already checked all above options.
but I am getting this error.
Do you know what its asking for. I am running GP Tool because this tools never worked for me.
@GIS_Solutions Did you ever figure out what the main issue is here?
Hello @bhaskarsingh1se This message means that the Append operation didn't find any network features/objects currently selected in the specified/active network map.Please check the following points- Do you already select the network features/objects you want to append to your diagram?
- If yes, in which network map is this selection set ? Did you specify that input network map so the append command searches for these input selected features/objects; that is, did you select the right map from the Input Map drop down list in the tool, or from the list under the Append button in the Network Diagram ribbon?
Please also make sure that the features/objects selected in this map are "network" features/objects; that is, they are related to network source classes.Any selected feature/object that doesn't belong to any network source class cannot be used to create any diagram, nor to be appended to any existing diagram.
