I try to append two feature layers in my ArcGIS portal. I'm using arcgis.geoanalytics module to do this. I manage to append these layers without using field mapping, I only pass the input layer and append layer parameter. However, I can't append these layers if I'm using field_mapping parameter. I have read this documentation but there is no example of field_mapping script. https://developers.arcgis.com/python/api-reference/arcgis.geoanalytics.manage_data.html#append-data
Maybe some example of field_mapping parameter would help me. Thank you!
Hi @AriMatiur,
The REST API documentation for the tool outlines the field mapping parameters here. Here is an example:
[{ "inputLayerField": "Mean_Scales", "mappingType": "AppendField", "mappingValue": "Average_Scales" },{ "inputLayerField": "Bonus", "mappingType": "Expression", "mappingValue": "$feature['WeeklyRate'] * 1.5" },{ "inputLayerField": "Errors", "mappingType": "Expression", "mappingValue": "null" }]
I agree that it's confusing that it's different than expected and then not clearly documented in the ArcGIS API for Python. I've put in a request to have the ArcGIS API for Python documentation include an example.
Please let me know if you have any follow up questions,
Sarah AmbroseGeoAnalytics Team
It's working, thank you Sarah 😁
Yeah, other Python API tool field_mapping use list or KVPs. I don't know why this one is different.Anyway, thank you very much.
Yeh I only came across that type of field mapping in another Python API tool, was worth a go I guess.
This tool's documentation for the field_mapping parameter is awful.
Hello David
It still not working
I think it may be a list of lists rather than KVPs:
field_mapping = [['kelurahan', 'kelurahan'], ['kecamatan','kecamatan']]
