If you have the editor defined in the resources, note that WPF (as opposed to Silverlight) doesn't support ElementBinding, so you will have to set the Map property in codebehind.
<ListBox x:Name="MyList" ItemsSource="{Binding ElementName=MyMap, Path=Layers}"> <ListBox.ItemTemplate> <DataTemplate> <StackPanel Orientation="Horizontal"> <!--Layer visibility checkbox--> <CheckBox IsChecked="{Binding Visible, Mode=TwoWay}" /> <!--Opacity slider--> <Slider Margin="-5,0,0,0" Minimum="0" Maximum="1" Width="30" Value="{Binding Opacity, Mode=TwoWay}" Height="18" /> <!--Layer name--> <TextBlock Text="{Binding ID, Mode=OneWay}" Margin="5,0,0,0" > <!-- Tooltip on hover--> <ToolTipService.ToolTip> <StackPanel MaxWidth="400"> <TextBlock FontWeight="Bold" Text="{Binding CopyrightText}" TextWrapping="Wrap" /> <TextBlock Text="{Binding Description}" TextWrapping="Wrap" /> </StackPanel> </ToolTipService.ToolTip> </TextBlock> </StackPanel> </DataTemplate> </ListBox.ItemTemplate> </ListBox>
Public Class MapFeatureSelect Private _vm As New LayerViewModel Public MyEditor As New ESRI.ArcGIS.Client.Editor Sub New() DataContext = _vm Resources.Add("MyEditor", MyEditor) ' This call is required by the designer. InitializeComponent() ' Add any initialization after the InitializeComponent() call. EditorToolStrip.DataContext = MyEditor End Sub Private Sub MyMap_Loaded(ByVal sender As Object, ByVal e As System.Windows.RoutedEventArgs) Handles MyMap.Loaded Dim lst As New List(Of String) lst.Add("SelectionLayer") With MyEditor .Map = MyMap .SelectionMode = ESRI.ArcGIS.Client.DrawMode.Rectangle .LayerIDs = lst End With End Sub End Class
