Update after toggling snapping off and back on in the user settings I was able to get it to snap to an existing line vertex. In order for the snap to work it looks like you have to be zoomed in quite far on the map. This isn't ideal since we are collecting data during aerial surveys. At what scale or zoom level should snapping work. In the desktop environment you can be zoomed out quite far, but still get the snapping capability? Thanks!
We are migrating our surveys from using ArcGIS Collector to Field Maps. We have been unable to get snapping to work. It is enabled in the user settings. When I click to collect a line near an existing line I do not see any snapping (orange points) show in the map. Other surveyors have also not been able to snap.
Are there are settings in the web map settings or reference layers that also need to be set?
Thanks in advance for your help,
Kathy
