I am running ArcPro. I am curious if there is a way to create a path on a DEM from one point to another? I used lidar to create my DEM. Any ideas?
Create polyline features—ArcGIS Pro | Documentation
Ok, I dont think that would work either. there are hills and small canyons between the two. Thanks anyways!
Unless the wagon trail could be delineated using a flow direction/accumulation/streamflow process, I suspect you will have some difficulty coming up with a set of rules to delineate it.
I am attempting to find the shortest distance between the two points. Supposedly where I am looking at there are an old wagon trail that can still be made out and I am not sure where to look. So I figured that they would take the shortest and smoothest path between the two places. Does that make sense?
There are many types of "paths"
Cost path?
Cost Path As Polyline (Raster Analysis)—ArcGIS Pro | Documentation
Shortest path?
Determine Travel Cost Paths To Destinations (Raster Analysis)—ArcGIS Pro | Documentation
your end goal would be useful
