I have a survey built using Connect version 3.12. 195 beta and field app version 3.12.233 on IOS. The survey links to an existing feature service on Enterprise Portal version 19.8.1. The feature service is published from a SQL Server 2016 database
Procedure - I open the survey on IOS then click the Inbox/Refresh to load past surveys. The Inbox opens with a list of surveys that were poorly named in previous versions of Survey123. Can I rename these previous surveys using fields from the survey in a batch process? How would I do this? Where is this name stored?
