The OS disk on which Spatiotemporal Big Data Store was running was full. After extending the partition, I see that I'm getting the following errors in GeoEvent Server like the following:
| Error trying to generate the JSON from a GeoEvent to store in the Spatiotemporal Big Data Store. Error: Unexpected failure occurred when writing to the spatiotemporal big data store for data source "HistoricalAIS". Failed to fetch the next batch of ObjectIds. Error: Unexpected failure occurred when writing to the spatiotemporal big data store for data source "HistoricalAIS". Failed to fetch the next batch of ObjectIds. Error: Unexpected failure occurred when writing to the spatiotemporal big data store for data source "HistoricalAIS". Failed to fetch the next batch of ObjectIds. Error: Map(type -> cluster_block_exception, reason -> blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];). |
I've seen by Googling that the error FORBIDDEN/12/index read-only / allow delete (api)] can occur when the disk becomes full, but that it can be reset. Does anyone know how to do this?
