I have created a custom Arcade expression for a layer's symbology based on two attribute fields, Land Use and Revised Land Use. If the Revised Land Use field is empty, then symbolize the parcel based on the Land Use field but if the Revised Land Use is not empty, then symbolize the parcel based on that field. The two attributes share the same coded domains of 28 possible values. The layer contains parcel data for the entire county so there are approximately 300,000 parcels. My issue is that when ArcGIS Online generates symbology based on the custom expression, it only samples a subset of the data and does not return the full list of possible values. My question is how do I get ArcGIS Online to sample the full dataset so that I can configure the symbology for all possible values?
I have read this post but the solution presented is not ideal. Can anyone point me in the right direction?
Miguel Fernandez
