We take measurements of our assets (poles) and use S123 very effectively. One of the field staff asked to see if using the device inbuild compass as a possible spirit level tool and read the values inside S123; ie need to calculate pole lean.
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-a-built-in-compass/ba-p/1121102
thank you @IsmaelChivite , this is great! Would it be possible to calculate the lean of the Pole in the current version? What i understand from your Bog it is the direction of the lean only, but not the magnitude.
i.e. now i am able to capture in which direction of the leaning pole ie 227deg, but not the actual pole lean i.e. 30deg. I would like to know the unit vector. S123 now had the ability of ϕ, but i was also looking at θ at an attribute. Hope this makes sense.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
