Good afternoon, all, and Happy New Year!
I've run into a snag with our new ArcGIS Enterprise deployment, and could use some guidance. On our old deployment, which was just an ArcGIS Server for Workgroups, I'd published a handful of large aerial images via ArcMap, dynamically cached, and all seemed to more or less work fine. With the new full-blown Enterprise deployment, I'm now trying to publish these same aerial images to Portal as hosted, tiled services. The first few went fine, but they're older, with lower resolution (i.e. smaller files), and once I move up to newer images I get a generic publication failure error in ArcGIS Pro. I also tried publishing as a web layer from Catalog, using similar settings to the old deployments created in ArcMap, but Pro presents that same error message.
The error comes up in Pro when I set the services to cache on the server, and when I try and publish via Catalog, with caching done dynamically (which is how our old services are set up).
Any thoughts on what I could be doing wrong? There's definitely a correlation whereby the larger files are the ones that won't publish, but I suppose it could be something else...
Thank you!
