When will the ArcGIS Solutions Deployment Tool be available for Pro 2.7?
Currently the Add-in is supporting ArcGIS Pro 2.4 - 2.6 (Basic, Standard, or Advanced).
Regards,
Saranya
Hi @S6 , I am working with 2.7 and was able to access the Update Domain Tool. I am curious if you cloned your python environment. I have experienced problems in the past with upgrading Pro and a cloned python environment breaking after the upgrade. When I delete the cloned environments it typically fixes this issue.
Has Pro 2.7 been released?
Yes.
I guess I missed the announcement; @KoryKramer would you care to comment on this? I run the Address Data Management Solution, so I won't be upgrading till that gets the green light.
@JoeBorgione, Address Data Management is certified for Pro 2.7. If you see our current documentation we list it as supported in versions 2.5 or later. We certify with every new release of Pro and only release an update if something is not longer compatible.
@Anonymous User this is true for the Solution Deployment Tool. The current version of the add-in will work in 2.7.
Thanks @ChrisFox !
Thanks! When I tried deploying the solution, it failed in Pro 2.7. The error message I got was "Update Domain Tool not available". So I checked the Solutions Deployment Tool page, the following was mentioned in the requirement section.
So I tried again in Pro 2.6 - it was working fine. So I assumed Pro 2.7 uodate is pending.
I haven't yet upgraded to 2.7 but plan to in the next (working) day or so. When upgrading to a new version of ArcGIS Pro, if you have cloned environment that the previous version pointed to, that environment is no longer available to your newest version. This is one of the reasons I'm always hesitant to upgrade. Seems like I get an environment just the way I want it with additional packages and ArcGis Pro gets version change. Incremental upgrades (2.6 to 2.6.1) will honor the current, active clone.
Oh! will definitely try this...thanks 🙂
