I am proposing that all Esri ArcGIS Enterprise Technical Support articles/documentation regarding common issues in Windows also have a corresponding article/documentation for Linux if the issue exists in both Windows and Linux environments.
For example, the issue described in this Esri Technical Support article (https://support.esri.com/en/technical-article/000012007) is valid for both Windows and Linux. However, the article only references Windows environments. I experienced this issue yesterday in a Linux environment, yet the only documentation that exists for this issue is for Windows. We had to do a lot of searching around to find the file in a Linux environment. If an issue for any Esri product is possible to exist in both Windows and Linux, then the article should have troubleshooting steps for both environments, not just Windows by default. The link I posted above is just a single example, but it is a common issue.
I realize most organizations probably choose Windows to deploy ArcGIS Enterprise, but if Esri is going to support Linux, then Esri's Technical Support articles should have troubleshooting steps for both Windows and Linux environments if the issue the article is describing exists in both environments. The article shouldn't be in Windows by default, with Linux users left to troubleshoot the issue on their own.
