I am using Experience Builder in ArcGIS Enterprise 10.8.1. In Embed Widget, how can I use the expression?
I need to concat my url with GlobalID field. I can't make it work.
Hi Azin,
Please try to use quotation marks around the static text.
Shengdi
Thank you Shengdi. It is working now.
I couldn't copy the URL from the clipboard into the Expression so I typed all the long url. This is a different issue.
I don't know why we can't paste text inside expressions. I've had to type hundreds of characters already and it's a pain...
@BrunoSousa1 The reason, to put it simply, is that the copy & paste function does not only evlove the strings/codes themselves that we can see from the UI but also needs to support the data source structure behind it if evolved, e.g. getting the field id from multiple data sources, etc.
We are working on these kinds of enhancements to provide a better user experience in the future. Thanks for staying with us.
Best,
Tonghui
Btw, a friend of mine found a workaround for pasting strings into the expression. He just opened developer tools on the browser and found the html for the expression box and pasted the URL there. The pasted text shows up in the UI and you can save it from there.
That works??!
Edit April 2021: No, not in Firefox browser, at least.
I have tried this for the URL link on a Button widget, and I cannot save the application after adding the dynamic field. So my parameter isn't passed in. Technically this should work but I can't get this to save in order to test it out.
@Anonymous User any idea how to deal with this?
(Workflow is passing parameters to a webhook that will create a Survey123 report using the Rest api)
Hi, you were still in the editing state before you clicked the Insert button, so the Save button is not enabled.
I believe your expression should look like this:"https://www.myurl.com/"+{GlobalID}With quotes and plus sign
For record-keeping: 11-18-2020 post from Anonymous User belongs to @ShengdiZhang.
