Hi everyone!
Hopefully this is an easy question, I am just struggling to figure it out despite my reading.
I have two data sets containing polygons. They polygons represent the same thing, but the data is from two different dates. As such, the polygons are in the same location, they've just changed in size/shape.
The first data set has each polygon labelled (e.g. A, B, C...) and the second data set has each polygon labelled a different way (e.g. 1, 2, 3). I want to combine these attribute tables to see that Polygon A is the same as Polygon 1, etc.
Whats the best way of doing this?
I've tried the join function which ends up only shows one data set, and the merge function shows one data set and <null> for the other in the resulting attribute table.
Thanks in advance!
Polygons:
