Hi ,
Is there any way to generate a grid shapefile in ArcGIS pro from Image tiles? Please find an attached images of the image tiles.
hI,
Thanks for your reply, but I required a tool or solution where we can generate a normal grid from image tiles which can be added as a shapefile to view the image name in ArcGIS Pro.
If you have the 3D Analyst Extension, you can run the Raster Domain GP tool to create the polygon feature class in a geodatabase or shapefile. If you don't have the 3D Analyst extension but do have the Spatial Analyst extension, then you can 1. Multiply the raster by 0 to create a constant value raster using the Raster Calculator (integer cell type) 2. Convert the output from Step 1 to a polygon using the Raster to Polygon GP tool. Hope this helps!
