https://maps.waterdata.usgs.gov/mapper/wateralert/
I've tried to add it under several types of the "Add Layer from Web" option, but it usually makes the data static. Any ideas? TIA!
Charlotte White
Have you tried setting the refresh interval?
Set refresh interval—Portal for ArcGIS | Documentation for ArcGIS Enterprise
Hi Rickey. I'm unable to even get past this page to add the live data. Do I need to use a different link?
have you tried using this url?
https://earthobs1.arcgis.com/arcgis/rest/services/Live_Stream_Gauges/MapServer
Yes I do have the stream gauges but I was trying to add the rain gauges as well. I'm not sure how to do that. Thank you so much for your responses!
