This functionality was removed in 10.0 (due to the new Item Description framework)
Randy, I am having the same problem. Did you ever find a solution? You are right--when you right-click on the model in ArcCatalog, you can select "Help" and see the process-by-process description, but I have found no way to edit that description. Removing this functionality was a bad idea; a general model "Item Description" does not pay the bills for documenting model processing. We need to be able to create an explanation for each tool. Hopefully someone has found a way to edit/create this documentation, especially since you CAN see it when you open the Help. Doesn't make sense if it's there in the "help" but you can't input that information. Thanks. Tyler
Does this article help?HowTo: Add descriptive text in the model dialoghttp://resources.arcgis.com/content/kbase?fa=articleShow&d=38595Please let me know if you have any feedback on this process!
In following up on these issues, I have discovered the following:In ArcCatalog, select (highlight) the tool in the Catalog Tree window first, then right-click the tool in the ArcToolbox window. Click on Item Description & click on the Edit button in the Item Description window. Make edits as needed (e.g., Dialog Reference, etc.) & click save. Now, when the tool is re-opened, its dialog will show the documentation revisions.So, yes, I found what I was missing, & I hope this helps others. But I feel that ESRI should clarify their Help documentation on this topic. In "A quick tour of documenting tools and toolboxes" in ArcGIS 10 Help, it should state upfront that the tool needs to be selected in the Catalog Tree window before doing anything.Chris MorneauL.A. County Dept. of Regional Planning
I'm afraid I dont see the "Item Description" option at all. I am using ArcGIS 10, full version. (Build 2800)When I right click on my model, I get:Open...Batch...Edit...Debug...CopyDeleteRenameSet Password...Export Script (grayed)Import Script (grayed)HelpPropertiesI don't see any Item Description.
Whenever I create a new model or process I also create a Word doc with directions on how to use it in addition to filling out the pertinent metadata. I have found what works best for me is that we have a FTP site, but I assume a DropBox would work also, where I put my documents and I simply hyperlink them to the metadata. Works well for adding those extra steps.
