A few little modifications would be make this widget perfect:
I'd like to add two more.
1. Enable the user to give a new for the resulting layer instead of Query Name_Result. This is especially useful if you have the create new layer each time the query is run option enabled. Sometimes, I want to see two different subsets of the same layer / service on the map and then run some analysis. It is hard to remember which one is which.
2. Enable the user to remove those layers from the map directly from the Layer widget instead of re-opening the query widget. I often end up with many query layers as I use it to view a trade area of a specific location.
I would like to see the following also:
1. Select multiple, non-adjacent features into a selection set with shapes (i.e. enable placement of multiple selection shapes before Apply).
4. Support add-to/remove-from (in addition to the current create-new) operations on selection sets (should also apply to the Select widget).
投稿、コンテンツのフォローなどにはサインインしてください。初めてですか?無料で登録しましょう。
