I would like to have the ability to reorder the Lookup Layers in the Lookup Layer tab for the Information Lookup webapp template. It currently orders the layer in reverse order with feature services followed map image services . This makes it difficult to order the layers to show in a logical fashion in the web map that is being used and within the information lookup popup that summarizes the data. Simple drag and drop or some sort of up/down arrow interface would be greatly appreciated. Thanks.
I have the same issue. This ordering is also a problem in other similar applications.
I am also having this issue. Did you find a solution or work around besides reordering your map layers?
投稿、コンテンツのフォローなどにはサインインしてください。初めてですか?無料で登録しましょう。
