...clusters comprised of the smallest number of grid cells that meet a given threshold value.
Given a raster dataset, I am looking to identify clusters of X number of cells (or less) whose values sum up to a certain number. i.e. The output would spatially identify clusters in the dataset where each cluster is comprised of 20 cells (or less) and the sum of those cells is 1000.
Hi, I'm using partition tools and need support.When i run Partition tools -I have added a iterate feature by field 'geo_county', the model stop and show this error.PYTHON ERRORS:Traceback Info: File "C:\FERRAN\SOFT\0 GIS\SIG EXTENSIONS\DISTRICTING ARCGIS\AS16021\PartitioningTools\Scripts\Collocate.py", line 128, in <module> if count % (int(0.05 * tot_features)) == 0:Error Info: <type 'exceptions.ZeroDivisionError'>: integer division or modulo by zeroIs a turnaround to this?Thanks for your attention,Ferran
