This folder contains the demos and slides from the Administering your Enterprise Geodatabase using Python tech session at Esri Developer Summit 2016
Well I get tons of errors when I run thi script but my own script runs fine. I use SYSTEM but your demo vids the lady used SYSTEM first and then ran it again with NO_SYSTEM. had me curious.
Iinclude_systemIndicates whether statistics will be gathered on the states and state lineages tables.Note:You must be the geodatabase administrator for this option to be activated.This option only applies to geodatabases. If the input workspace is a database, this option will be ignored.NO_SYSTEM —Statistics will not be gathered on the states and state lineages tables. This is the default.SYSTEM —Statistics will be gathered on the states and state lineages tables.
I
Analyze Datasets—Help | ArcGIS Desktop here is the help documentation on the tool.
Verify that you are using the correct user connection (SDE) for the SYSTEM tables and the DATA owner for the other tables.
What is the difference when running Analyze Data and Rebuilding indexes with the parameters (NO_SYSTEM/SYSTEM). SHould I run it both like the video??? I get an error when I try to run NO_SYSTEM.
Adding a few other groups....... Thanks for those tools and slides!
Managing Data Enterprise GIS
